New interface
Conference papers
Formal Derivation and Extraction of a Parallel Program for the All Nearest Smaller Values Problem
Abstract : The All Nearest Smaller Values (ANSV) problem is an important problem for parallel programming as it can be used to solve several problems and is one of the phases of several other parallel algorithms. We formally develop by construction a functional parallel program for solving the ANSV problem using the theory of Bulk Synchronous Parallel (BSP) homomorphisms within the Coq proof assistant. The performances of the Bulk Synchronous Parallel ML program obtained from Coq is compared to a version derived without software support (pen-and-paper) and implemented using the Orléans Skeleton Library of algorithmic skeletons, and to a (unproved correct) direct implementation of the BSP algorithm of He and Huang.
Complete list of metadata
https://hal.inria.fr/hal-00905950
Contributor : Frédéric Loulergue Connect in order to contact the contributor
Submitted on : Tuesday, November 19, 2013 - 8:46:11 AM
Last modification on : Saturday, June 25, 2022 - 10:12:26 AM
Identifiers
  • HAL Id : hal-00905950, version 1
Collections
Citation
Frédéric Loulergue, Simon Robillard, Julien Tesson, Joeffrey Legaux, Zhenjiang Hu. Formal Derivation and Extraction of a Parallel Program for the All Nearest Smaller Values Problem. ACM Symposium on Applied Computing (SAC), 2014, Gyeongju, South Korea. ⟨hal-00905950⟩
Share
Metrics
Record views
166
