New interface
Journal articles
Age effect in recall performance according to the levels of processing, elaboration, and retrieval cues.
Abstract : The present study was conducted to investigate the incidence of several factors contributing to age-related memory decrement. Variables manipulated include quality (level of processing encoding conditions), the degree of effort and encoding quantitative elaboration (active/passive encoding conditions), and the influence of retrieval support (free-/cued recall conditions). In support of the environmental support hypothesis, middle-old and old subjects benefited more than young ones from cued recall in all the memory tests. Moreover, the results showed a differential (qualitative vs. quantitative) impairment of conceptual processing between the middle-old and the old-age groups. In the middle-olds, age differences were abolished by deep processing in old adults, age differences were attentuated only with deep and active processing associated with retrieval support. These gradual memory impairments are evaluated according to Mandler's model of memory (1979, In L. G. Nilsson [Ed.], Perspective in memory research. Hillsdale: Lawrence-Erlbaum), and the environmental support hypothesis is discussed in terms of the involvement of encoding and retrieval operations required by the memory task.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-00908012
Contributor : Hélène Sauzeon Connect in order to contact the contributor
Submitted on : Friday, November 22, 2013 - 10:59:37 AM
Last modification on : Saturday, June 25, 2022 - 8:53:54 PM
Identifiers
Citation
Hélène Sauzéon, Bernard N'Kaoua, V. Lespinet, F. Guillem, B. Claverie. Age effect in recall performance according to the levels of processing, elaboration, and retrieval cues.. Experimental Aging Research, 2000, 26 (1), pp.57-73. ⟨10.1080/036107300243687⟩. ⟨hal-00908012⟩
Share
Metrics
Record views
132
