Decidability Problems for Actor Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We introduce a nominal actor-based language and study its expressive power. We have identified the presence/absence of fields as a relevant feature: the dynamic creation of names in combination with fields gives rise to Turing completeness. On the other hand, restricting to stateless actors gives rise to systems for which properties such as termination are decidable. Such decidability result holds in actors with states when the number of actors is finite and the state is read-only.
Informatique
hal-00909366 , version 1 (26-11-2013)
Frank S. De Boer, Mohammad Mahdi Jaghoori, Cosimo Laneve, Gianluigi Zavattaro. Decidability Problems for Actor Systems. CONCUR 2012 - 23rd International Conference on Concurrency Theory, Sep 2012, Newcastle, United Kingdom. pp.562-577, ⟨10.1007/978-3-642-32940-1_39⟩. ⟨hal-00909366⟩
Collections
INRIA INRIA2
108 Consultations
0 Téléchargements
