A note on an IND-CCA2 secure Paillier-based cryptosystem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Information Processing Letters Année : 2013
Recently an IND-CCA2 secure Paillier-based cryptosystem has been proposed (Das and Adhikari, 2012 [1]). In this note we show that Das and Adhikari do not present any original result: their scheme is a rewriting of the well-known Fujisaki-Okamoto IND-CPA to IND-CCA2 transformation applied to the Paillier scheme.
hal-00909726 , version 1 (26-11-2013)
David Galindo. A note on an IND-CCA2 secure Paillier-based cryptosystem. Information Processing Letters, 2013, 113 (22-24), pp.913-914. ⟨10.1016/j.ipl.2013.09.008⟩. ⟨hal-00909726⟩
152 Consultations
0 Téléchargements
