Active Signaling for 802.11 Networks in the ns-3 Simulator - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Hana Baccouch
  • Fonction : Auteur
  • PersonId : 949116
Cédric Adjih
Paul Mühlethaler
  • Fonction : Auteur
  • PersonId : 833453
In wireless networks, wireless channels are often shared between multiple nodes, which may interfere when they transmit simultaneously. The media access control (MAC) scheme coordinates channel access between the different nodes. In this article, we focus one specific method of channel access, Elimination-Yield Non-Preemptive Priority Multiple Access, EY- NPMA, which is part of the European standard wireless HIPERLAN. EY-NPMA is a wireless MAC method that partly relies on "active signaling": i.e. transmitting (activity) to simply signal a node's presence (with pseudo-noise), rather than transmitting data (bits). In this article, we study the adaptation of EY-NPMA named Ey-Wifi as an extension of the 802.11-based standards. Our main focus is the implementation of a such an extension in a module of the network simulator, ns-3, with the emphasis on the software architecture.
article-pemwn.pdf (240.09 Ko) Télécharger le fichier
hal-00911319 , version 1 (29-11-2013)
  • HAL Id : hal-00911319 , version 1
Hana Baccouch, Cédric Adjih, Paul Mühlethaler. Active Signaling for 802.11 Networks in the ns-3 Simulator. PEMWN 2012 : First International Workshop on Performance Evaluation and Modeling in Wireless Networks, Nov 2012, Tunis, Tunisia. ⟨hal-00911319⟩
228 Consultations
326 Téléchargements
