QoS Contract Preservation through Dynamic Reconfiguration: A Formal Semantics Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Science of Computer Programming Année : 2014
The increasing pervasiveness of computing services in everyday life, combined with the dynamic nature of their execution contexts, constitutes a major challenge in guaranteeing the expected quality of such services at runtime. Quality of Service (QoS) contracts have been proposed to specify expected quality levels (QoS levels) on different context conditions, with different enforcing mechanisms. In this paper we present a definition for QoS contracts as a high-level policy for governing the behavior of software systems that self-adapt at runtime in response to context changes. To realize this contract definition, we specify its formal semantics and implement it in a software framework able to execute and reconfigure software applications, in order to maintain fulfilled their associated QoS contracts. The contribution of this paper is threefold. First, we extend typed-attributed graph transformation systems and finite-state machines, and use them as denotations to specify the semantics of QoS contracts. Second, this semantics makes it possible to systematically exploit design patterns at runtime by dynamically deploying them in the managed software application. Third, our semantics guarantees self-adaptive properties such as reliability and robustness in the contract satisfaction. Finally, we evaluate the applicability of our semantics implementation by integrating and executing it in FraSCAti, a multi-scale component-based middleware, in three case studies.
SCICO-D-11-00245R3.pdf (1.37 Mo) Télécharger le fichier
hal-00911844 , version 1 (30-11-2013)
Gabriel Tamura, Rubby Casallas, Anthony Cleve, Laurence Duchien. QoS Contract Preservation through Dynamic Reconfiguration: A Formal Semantics Approach. Science of Computer Programming, 2014, Selected best papers from the 7th International Workshop on Formal Aspects of Component Software (FACS 2010), 94 (3), pp.25. ⟨10.1016/j.scico.2013.12.003⟩. ⟨hal-00911844⟩
166 Consultations
222 Téléchargements
