Using noisy georeferenced information sources for navigation and tracking - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Localization, navigation and tracking form a special application domain of Bayesian filtering, where the position and velocity of a mobile (and possibly additional hyper-parameters) should be estimated based on (i) a prior model for the possible displacement of the mobile, (ii) noisy measurements provided by a sensor, and (iii) a georeferenced information source (digital map, reference data base, etc.), providing for each spatial position an estimate of the quantity measured by the sensor. For example in terrain-aided navigation (TAN) a radio-altimeter combined with an inertial navigation system (INS) provides an estimation of the terrain height below the platform, which can be correlated with the terrain height at each horizontal position, as read on a digital map. In wireless communications, the signal power received by the mobile from an access point (WiFi) or from a base station (GSM, UMTS) and measured by the mobile itself, can be correlated with another estimation of the signal power received at each spatial position, as read on a digital attenuation map or from a reference data base. Values read on a digital map are usually subject to errors which are in general spatially correlated and modeled as Gaussian random fields, with a known correlation function. This results in a temporal correlation of measurement noises, which should be accounted for in evaluating the likelihood function, an essential step in the derivation of the equation for the Bayesian filter.
Fichier non déposé
hal-00912050 , version 1 (02-12-2013)
Julien Guillet, François Le Gland. Using noisy georeferenced information sources for navigation and tracking. Proceedings of the IEEE Workshop on Nonlinear Statistical Signal Processing (NSSP), Cambridge 2006, IEEE--SPS, Sep 2006, Cambridge, United Kingdom. pp.156-159, ⟨10.1109/NSSPW.2006.4378843⟩. ⟨hal-00912050⟩
96 Consultations
0 Téléchargements
