Dynamic consistent correlation-variational approach for robust optical flow estimation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Experiments in Fluids Année : 2008
We present in this paper a novel combined scheme dedicated to the measurement of velocity in fluid experimental flows through image sequences. The proposed technique satisfies the Navier-Stokes equations and combines the robustness of correlation techniques with the high density of global variational methods. It can be considered either as a reenforcement of fluid dedicated opticalflow methods towards robustness, or as an enhancement of correlation approaches towards dense information. This results in a physics-based technique that is robust under noise and outliers, while providing a dense motion field. The method was applied on synthetic images and on real experiments in turbulent flows carried out to allow a thorough comparison with a state of the art variational and correlation methods.
hal-00914361 , version 1 (05-12-2013)
Etienne Mémin, Dominique Heitz, Patrick Héas, Johan Carlier. Dynamic consistent correlation-variational approach for robust optical flow estimation. Experiments in Fluids, 2008, 45 (4), pp.595-608. ⟨10.1007/s00348-008-0567-4⟩. ⟨hal-00914361⟩
92 Consultations
0 Téléchargements
