Randomized parcellation based inference. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue NeuroImage Année : 2013
Vincent Frouin
Neuroimaging group analyses are used to relate inter-subject signal differences observed in brain imaging with behavioral or genetic variables and to assess risks factors of brain diseases. The lack of stability and of sensitivity of current voxel-based analysis schemes may however lead to non-reproducible results. We introduce a new approach to overcome the limitations of standard methods, in which active voxels are detected according to a consensus on several random parcellations of the brain images, while a permutation test controls the false positive risk. Both on synthetic and real data, this approach shows higher sensitivity, better accuracy and higher reproducibility than state-of-the-art methods. In a neuroimaging-genetic application, we find that it succeeds in detecting a significant association between a genetic variant next to the COMT gene and the BOLD signal in the left thalamus for a functional Magnetic Resonance Imaging contrast associated with incorrect responses of the subjects from a Stop Signal Task protocol.
persistence.pdf (684.73 Ko) Télécharger le fichier
supplementary_material.pdf (127.01 Ko) Télécharger le fichier
supplementary_material1.pdf (106.19 Ko) Télécharger le fichier
Format : Autre
hal-00915243 , version 1 (06-01-2014)
Benoit da Mota, Virgile Fritsch, Gaël Varoquaux, Tobias Banaschewski, Gareth J. Barker, et al.. Randomized parcellation based inference.. NeuroImage, 2013, epub ahead of print. ⟨10.1016/j.neuroimage.2013.11.012⟩. ⟨hal-00915243⟩
1202 Consultations
960 Téléchargements
