New interface
Conference papers
On Matrices, Automata, and Double Counting
Nicolas Beldiceanu 1 Mats Carlsson 2 Pierre Flener 3 Justin Pearson 3
1 TASC - Theory, Algorithms and Systems for Constraints
LINA - Laboratoire d'Informatique de Nantes Atlantique, Département informatique - EMN, Inria Rennes – Bretagne Atlantique
Abstract : Matrix models are ubiquitous for constraint problems. Many such problems have a matrix of variables M, with the same constraint defined by a finite-state automaton A on each row of M and a global cardinality constraint gcc on each column of M . We give two methods for deriving, by double counting, necessary conditions on the cardinality variables of the gcc constraints from the automaton A. The first method yields linear necessary conditions and simple arithmetic constraints. The second method introduces the cardinality automaton, which abstracts the overall behaviour of all the row automata and can be encoded by a set of linear constraints. We evaluate the impact of our methods on a large set of nurse rostering problem instances.
Complete list of metadata
https://hal.inria.fr/hal-00915717
Contributor : Contraintes Lina Connect in order to contact the contributor
Submitted on : Monday, December 9, 2013 - 11:52:18 AM
Last modification on : Wednesday, April 27, 2022 - 3:42:22 AM
Links full text
Identifiers
Citation
Nicolas Beldiceanu, Mats Carlsson, Pierre Flener, Justin Pearson. On Matrices, Automata, and Double Counting. Integration of AI and OR Techniques in Constraint Programming for Combinatorial Optimization Problems, 7th International Conference, CPAIOR 2010, Bologna, Italy, June 14-18, 2010. Proceedings, Jun 2010, Bologna, Italy. ⟨10.1007/978-3-642-13520-0_4⟩. ⟨hal-00915717⟩
Share
Metrics
Record views
135
