New interface
Conference papers
SDR for SRD: ADC specifications for reconfigurable gateways in urban sensor networks
Mathieu Vallerian 1, 2 Guillaume Villemaud 1, * Benoit Miscopein 2 Tanguy Risset 1 Florin Hutu 1
* Corresponding author
1 SOCRATE - Software and Cognitive radio for telecommunications
Inria Grenoble - Rhône-Alpes, CITI - CITI Centre of Innovation in Telecommunications and Integration of services
Abstract : Short Range Devices (SRD) are increasingly employed in urban sensor networks using different communication protocols. That becomes a key problem in the gateway design, since its cost and energy consumption increase with the number of implemented technologies. This cost and energy can be reduced by using a reconfigurable gateway to perform the biggest part of signal processing digitally, as it is done in Software-Defined Radio (SDR). As several received signals should be simultaneously digitized, Analog-to-Digital Converter (ADC) must be able to treat the whole frequency band used by SRD, with a high enough resolution to properly demodulate the signals. This paper describes what the ADC's constraints are and how to dimension an ADC in SDR for SRD. An example based on the SmartSantander deployment shows that an ADC resolution of 23 bits is required to properly demodulate the data.
Document type :
Conference papers
Complete list of metadata
Cited literature [3 references]  Display  Hide  Download
https://hal.inria.fr/hal-00920906
Contributor : Guillaume Villemaud Connect in order to contact the contributor
Submitted on : Thursday, December 19, 2013 - 1:58:42 PM
Last modification on : Wednesday, March 9, 2022 - 3:29:56 PM
Long-term archiving on: : Thursday, March 20, 2014 - 6:00:28 AM
File
RWS2014_Vallerian.pdf
Identifiers
  • HAL Id : hal-00920906, version 1
Collections
Citation
Mathieu Vallerian, Guillaume Villemaud, Benoit Miscopein, Tanguy Risset, Florin Hutu. SDR for SRD: ADC specifications for reconfigurable gateways in urban sensor networks. IEEE Radio Wireless Symposium, Jan 2014, Newport Beach, United States. ⟨hal-00920906⟩
Share
Metrics
Record views
259
Files downloads
395
