New interface
Conference papers
Feet and legs tracking using a smart rollator equipped with a Kinect
Cyril Joly 1 Claire Dune 1 Philippe Gorce 1 Patrick Rives 2
2 Lagadic - Visual servoing in robotics, computer vision, and augmented reality
CRISAM - Inria Sophia Antipolis - Méditerranée , Inria Rennes – Bretagne Atlantique , IRISA-D5 - SIGNAUX ET IMAGES NUMÉRIQUES, ROBOTIQUE
Abstract : Clinical evaluation of frailty in the elderly is the first step to decide the degree of assistance they require. Advances in robotics make it possible to turn a standard assistance device into an augmented device that may enrich the existing tests with new sets of daily measured criteria. In this paper we use a standard 4 wheeled rollator, equipped with a Kinect and odometers, for biomechanical gait analysis. This paper focuses on the method we develop to measure and estimate legs and feet position during an assisted walk. The results are compared with motion capture data, as a ground truth. Preliminary results obtained on four healthy persons show that relevant data can be extracted for gait analysis. Some criteria are accurate with regards to the ground truth, eg. foot orientation and ankle angle.
Document type :
Conference papers
Complete list of metadata
Cited literature [16 references]  Display  Hide  Download
https://hal.inria.fr/hal-00921273
Contributor : Eric Marchand Connect in order to contact the contributor
Submitted on : Friday, December 20, 2013 - 10:32:03 AM
Last modification on : Thursday, January 20, 2022 - 4:20:32 PM
Long-term archiving on: : Friday, March 21, 2014 - 10:15:21 AM
File
Joly2013BiomecaKinect.pdf
Identifiers
  • HAL Id : hal-00921273, version 1
Citation
Cyril Joly, Claire Dune, Philippe Gorce, Patrick Rives. Feet and legs tracking using a smart rollator equipped with a Kinect. Workshop on "Assistance and Service Robotics in a Human Environment" in conjonction with IEEE/RSJ Int. Conf. on Int. Rob. and Sys. (IROS), Nov 2013, Tokyo, Japan. ⟨hal-00921273⟩
Share
Metrics
Record views
642
Files downloads
741
