The DFLU flux for systems of conservation laws - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational and Applied Mathematics Année : 2013
The DFLU numerical flux was introduced in order to solve hyperbolic scalar conservation laws with a flux function discontinuous in space. We show how this flux can be used to solve certain class of systems of conservation laws such as systems modeling polymer flooding in oil reservoir engineering. Furthermore, these results are extended to the case where the flux function is discontinuous in the space variable. Such a situation arises for example while dealing with oil reservoirs which are heterogeneous. Numerical experiments are presented to illustrate the efficiency of this new scheme compared to other standard schemes like upstream mobility, Lax-Friedrichs and Force schemes.
RR-8442.pdf (849.41 Ko) Télécharger le fichier
hal-00922936 , version 1 (31-12-2013)
Adi Adimurthi, G. D. Veerappa Gowda, Jérôme Jaffré. The DFLU flux for systems of conservation laws. Journal of Computational and Applied Mathematics, 2013, 247, pp.102-123. ⟨10.1016/j.cam.2012.12.025⟩. ⟨hal-00922936⟩
Collections
INRIA INRIA2
126 Consultations
144 Téléchargements
