Using Event-Based Style for Developing M2M Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we introduce how to write M2M applications by using INI, a programming language specified and implemented by ourselves that supports event-based style. With event-based programming, all M2M communication can be handled and scheduled. Programmers may use existing built-in events or define their own events. We apply our approach in a real M2M gateway, which allows gathering and exchanging information between sensors and machines in the network. The results shows that our work proposes a concise and elegant alternative and complement to industrial state-of-the-art languages such as Java or C/C++.
gpc2013_version_2_.pdf (145.71 Ko) Télécharger le fichier
hal-00924491 , version 1 (07-01-2014)
Truong Giang Le, Olivier Hermant, Matthieu Manceny, Renaud Pawlak, Renaud Rioboo. Using Event-Based Style for Developing M2M Applications. GPC - 8th International Conference on Grid and Pervasive Computing - 2013, 2013, Seoul, South Korea. pp.348-357, ⟨10.1007/978-3-642-38027-3_37⟩. ⟨hal-00924491⟩
346 Consultations
290 Téléchargements
