DRMSim: A Routing-Model Simulator for Large-Scale Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ERCIM News Année : 2013
The expansion of Internet topology, which comprises thousands of Autonomous Systems (AS), has resulted in a number of important research challenges. The Border Gateway Protocol (BGP), which is used to make core routing decisions on the Internet, starts to show its limitations in terms of the number of routing table entries it can store locally, update in a timely fashion and dynamically exchange. Because it is impractical to deploy newly designed routing protocols on the Internet a large-scale, simulation is an unavoidable step to validate their properties. However, the increasing routing information processing (CPU) and storage (memory) introduces similar challenges for the simulation of state-full routing. For this purpose, we introduce DRMSim a Dynamic Routing Model simulator of routing models on large-scale networks.
Fichier non déposé
hal-00924952 , version 1 (07-01-2014)
  • HAL Id : hal-00924952 , version 1
Aurélien Lancin, Dimitri Papadimitriou. DRMSim: A Routing-Model Simulator for Large-Scale Networks. ERCIM News, 2013, 94, pp.31-32. ⟨hal-00924952⟩
190 Consultations
0 Téléchargements
