Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, Epiciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Conference papers
Traitement de l'information scientifique et technique dans un contexte de veille : plateforme d'apprentissage multilingue
Sahbi Sidhom 1 Philippe Lambert 2
1 KIWI - Knowledge Information and Web Intelligence
LORIA - AIS - Department of Complex Systems, Artificial Intelligence & Robotics
2 Veille Technologique et ASIEs
Inalco - Institut National des Langues et Civilisations Orientales
Abstract : One of the challenges of Economic Intelligence, as completed in "The Economic Intelligence: guide for beginners and practitioners - Programme of the European Commission", is "to transform the mass of data available in different forms, from many sources, which is often unorganised, and collected through several channels, into information, and then into knowledge and then into intelligence" [2]. The focus presents a set of case studies for information monitoring methodology applied in multilingual context. Hence, we applied our theoretical schema to the project: specifically dedicated to chronic health and nanometrology domains gathering both academic labs and industries. Processing with NooJ with in multilingual resources is (i) to mine on actors linked to information needs in order to get the better management of the project, (ii) to determine the professional classes of each actor in the expertise domain and (iii) to link each concept in the domain with multilingual representations.
Complete list of metadata
https://hal.inria.fr/hal-00927193
Contributor : Sahbi Sidhom Connect in order to contact the contributor
Submitted on : Saturday, January 11, 2014 - 6:51:35 PM
Last modification on : Wednesday, October 27, 2021 - 2:40:01 PM
Identifiers
  • HAL Id : hal-00927193, version 1
Collections
Citation
Sahbi Sidhom, Philippe Lambert. Traitement de l'information scientifique et technique dans un contexte de veille : plateforme d'apprentissage multilingue. Cinquième journée Technopolice spécialisée (19 septembre 2013 à Paris (direction générale de la gendarmerie nationale (DGGN))., Technopolice 2013 - journée Technopolice spécialisée (19 septembre 2013 à Paris (direction générale de la gendarmerie nationale (DGGN))., Sep 2013, Paris, France. ⟨hal-00927193⟩
Share
Metrics
Record views
241
