Conference papers
Spatial modelling of plant diversity from high-throughput environmental dna sequence data
Angelika Studeny 1, * Florence Forbes 1, * Eric Coissac 2 Alain Viari 3 Celine Mercier 2 Lucie Zinger 2 Aurélie Bonin 2 Frédéric Boyer 2 Pierre Taberlet 2
* Corresponding author
1 MISTIS - Modelling and Inference of Complex and Structured Stochastic Systems
Inria Grenoble - Rhône-Alpes, LJK - Laboratoire Jean Kuntzmann, Grenoble INP - Institut polytechnique de Grenoble - Grenoble Institute of Technology
3 BAMBOO - An algorithmic view on genomes, cells, and environments
Inria Grenoble - Rhône-Alpes, LBBE - Laboratoire de Biométrie et Biologie Evolutive - UMR 5558
Abstract : This paper considers a statistical modelling approach to investigate spatial cross-correlations between species in an ecosystem. A special feature is the origin of the data from high-troughput environmental DNA sequencing of soil samples. Here we use data collected at the Nourague CNRS Field Station in French Guiana. We describe bivariate spatial relationships in these data by a separable linear model of coregionalisation and estimate a cross-correlation parameter. Based on this estimate, we visualise plant taxa co-occurrence pattern in form of 'interaction graphs' which can be interpreted in terms of ecological interactions. Limitations of this approach are discussed along with possible alternatives.
Complete list of metadata
https://hal.inria.fr/hal-00933699
Contributor : Florence Forbes Connect in order to contact the contributor
Submitted on : Monday, January 20, 2014 - 10:54:50 PM
Last modification on : Saturday, September 24, 2022 - 2:36:04 PM
Identifiers
  • HAL Id : hal-00933699, version 1
Citation
Angelika Studeny, Florence Forbes, Eric Coissac, Alain Viari, Celine Mercier, et al.. Spatial modelling of plant diversity from high-throughput environmental dna sequence data. 45èmes Journées de Statistique, Société Française de Statistique, May 2013, Toulouse, France. ⟨hal-00933699⟩
Share
Metrics
Record views
504
