Comparator: A Tool for Quantifying Behavioural Compatibility - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present Comparator, a tool that measures the compatibility between two behavioural interfaces. Comparator can be used as a stand-alone Web application, and is also integrated into a model-based adaptation toolbox.
OSPC-FASE_14.pdf (229.93 Ko) Télécharger le fichier
hal-00934057 , version 1 (21-01-2014)
Meriem Ouederni, Gwen Salaün, Javier Cámara, Ernesto Pimentel. Comparator: A Tool for Quantifying Behavioural Compatibility. FASE 2014 - 17th International Conference on Fundamental Approaches to Software Engineering, Apr 2014, Grenoble, France. pp.306-309, ⟨10.1007/978-3-642-54804-8_21⟩. ⟨hal-00934057⟩
423 Consultations
242 Téléchargements
