Journal articles
On relative errors of floating-point operations: optimal bounds and applications
Abstract : Rounding error analyses of numerical algorithms are most often carried out via repeated applications of the so-called standard models of floating-point arithmetic. Given a round-to-nearest function fl and barring underflow and overflow, such models bound the relative errors E 1 (t) = |t − fl(t)|/|t| and E 2 (t) = |t − fl(t)|/|fl(t)| by the unit roundoff u. This paper investigates the possibility and the usefulness of refining these bounds, both in the case of an arbitrary real t and in the case where t is the exact result of an arithmetic operation on some floating-point numbers. We show that E 1 (t) and E 2 (t) are optimally bounded by u/(1 + u) and u, respectively, when t is real or, under mild assumptions on the base and the precision, when t = x ± y or t = xy with x, y two floating-point numbers. We prove that while this remains true for division in base β > 2, smaller, attainable bounds can be derived for both division in base β = 2 and square root. This set of optimal bounds is then applied to the rounding error analysis of various numerical algorithms: in all cases, we obtain significantly shorter proofs of the best-known error bounds for such algorithms, and/or improvements on these bounds themselves.
Complete list of metadata
Cited literature [18 references]  Display  Hide  Download
https://hal.inria.fr/hal-00934443
Contributor : Claude-Pierre Jeannerod <>
Submitted on : Thursday, November 3, 2016 - 9:37:58 AM
Last modification on : Wednesday, November 20, 2019 - 2:48:23 AM
Long-term archiving on: : Saturday, February 4, 2017 - 12:44:11 PM
File
JeannerodRump2016.pdf
Identifiers
Collections
Citation
Claude-Pierre Jeannerod, Siegfried M. Rump. On relative errors of floating-point operations: optimal bounds and applications. Mathematics of Computation, American Mathematical Society, 2018, 87, pp.803-819. ⟨10.1090/mcom/3234⟩. ⟨hal-00934443v4⟩
Share
Metrics
Record views
921
Files downloads
1315
