Saliency-based modeling of acoustic scenes using sparse non-negative matrix factorization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The modelling of auditory scenes is a challenging task in Computational Auditory Scene Analysis. A method based on sparse Non-negative Matrix Factorization that can be used with no prior knowledge of the audio content to establish the similarity between scenes is proposed. The method is evaluated on a corpus of soundscapes of train stations issued from a perceptual study and results are compared with the human perception. The proposed method, by being able to focus on salient events within the scene, achieves better performances than a state-of-the-art Bag-of-Frames approach though not reaching the human performances.
Son [cs.SD]
Cauchi13-SparseSliencyNMG.pdf (396.88 Ko) Télécharger le fichier
hal-00940075 , version 1 (31-01-2014)
  • HAL Id : hal-00940075 , version 1
Benjamin Cauchi, Mathieu Lagrange, Nicolas Misdariis, Arshia Cont. Saliency-based modeling of acoustic scenes using sparse non-negative matrix factorization. Workshop on Image and Audio Analysis for Multimedia Interactive, Jul 2013, Paris, France. ⟨hal-00940075⟩
226 Consultations
271 Téléchargements
