On Association Cells in Random Heterogeneous Networks. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2013
Characterizing user to access point (AP) association strategies in heterogeneous cellular networks (HetNets) is critical for their performance analysis, as it directly influences the load across the network. In this letter, we introduce and analyze a class of association strategies, which we term stationary association, and the resulting association cells. For random HetNets, where APs are distributed according to a stationary point process, the area of the resulting association cells are shown to be the marks of the corresponding point process. Addressing the need of quantifying the load experienced by a typical user, a "Feller-paradox" like relationship is established between the area of the association cell containing origin and that of a typical association cell. For the specific case of Poisson point process and max power/SINR association, the mean association area of each tier is derived and shown to increase with channel gain variance and decrease in the path loss exponents of the corresponding tier.
hal-00940534 , version 1 (01-02-2014)
Sarabjot Singh, François Baccelli, Jeffrey G. Andrews. On Association Cells in Random Heterogeneous Networks.. [Research Report] University of Texas at Austin. 2013. ⟨hal-00940534⟩
108 Consultations
0 Téléchargements
