Blind signal decompositions for automatic transcription of polyphonic music: NMF and K-SVD on the benchmark - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
This paper investigates on the behavior of two blind signal decomposition algorithms, non negative matrix factorization (NMF) and non negative K-SVD (NKSVD), in a polyphonic music transcription task. State-of-the-art transcription systems are based on a frame-byframe, low-level approach; blind systems could be an alternative to them. Two raw but effective audio-to-MIDI systems are proposed and evaluated. Performances are similar, but in favor of NMF, which is more robust to initialization, choice of the order and computationnally less costly.
icassp-07-bis.pdf (102.88 Ko) Télécharger le fichier
hal-00945282 , version 1 (24-03-2014)
  • HAL Id : hal-00945282 , version 1
Nancy Bertin, Roland Badeau, Gael Richard. Blind signal decompositions for automatic transcription of polyphonic music: NMF and K-SVD on the benchmark. Proc. of IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), 2007, Honolulu, Hawaii, United States. pp.65--68. ⟨hal-00945282⟩
172 Consultations
468 Téléchargements
