Score informed audio source separation using a parametric model of non-negative spectrogram - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper we present a new technique for monaural source separation in musical mixtures, which uses the knowledge of the musical score. This information is used to initialize an algorithm which computes a parametric decomposition of the spectrogram based on non-negative matrix factorization (NMF). This algorithm provides time-frequency masks which are used to separate the sources with Wiener filtering.
hennequin_icassp2011.pdf (162.63 Ko) Télécharger le fichier
hal-00945294 , version 1 (24-03-2014)
  • HAL Id : hal-00945294 , version 1
Romain Hennequin, Bertrand David, Roland Badeau. Score informed audio source separation using a parametric model of non-negative spectrogram. Proc. of IEEE International Conference on Acoustics, Speech, and Signal Processing (ICASSP), 2011, Prague, Czech Republic. ⟨hal-00945294⟩
288 Consultations
612 Téléchargements
