Knowledge Based Query Processing in Large Scale Virtual Organizations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2009
This work concerns query processing to support data sharing in large scale Virtual Organizations(VO). Characterization of VO's data sharing contexts reflects the coexistence of factors like sources overlapping, uncertain data location, and fuzzy copies in dynamic large scale environments that hinder query processing. Existing results on distributed query evaluation are useful for VOs, but there is no appropriate solution combining high semantic level and dynamic large scale environments required by VOs. This paper proposes a characterization of VOs data sources, called Data Profile, and a query processing strategy (called QPro2e) for large scale VOs with complex data profiles. QPro2e uses an evolving distributed knowledge base describing data sources roles w.r.t shared domain concepts. It allows the identification of logical data source clusters which improve query evaluation in presence of a very large number of data sources.
Fichier non déposé
hal-00953018 , version 1 (28-02-2014)
Alexandra Pomares, Claudia Roncancio, José Abásolo, María Pilar Villamil. Knowledge Based Query Processing in Large Scale Virtual Organizations. Filipe, Joaquim and Cordeiro, José. Enterprise Information Systems, 24, Springer Berlin Heidelberg, pp.208-219, 2009, Lecture Notes in Business Information Processing, 978-3-642-01346-1. ⟨10.1007/978-3-642-01347-8_18⟩. ⟨hal-00953018⟩
85 Consultations
0 Téléchargements
