HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Using Software Metrics in the Evaluation of a Conceptual Component Model
Abstract : Every interactive system has a functional part and an interactive part. However the software engineering and the human-computer-interaction communities work separately in terms of methods, models and tools, which induces a work overhead for integrating the results of these efforts, as well as increased inconsistency risks. We endeavour to treat this problem by proposing a design method, which couples the functional kernel and the interaction design. In particular, this method proposes a specific way of structuring the interaction and the business spaces. The structure is based on components called Symphony Objects. In this article, we attempt to evaluate the technical aspect of a Symphony Object model issued from the method by measuring its implementations with software metrics.
Document type :
Conference papers
Complete list of metadata
Cited literature [17 references]  Display  Hide  Download
https://hal.inria.fr/hal-00953311
Contributor : Renaud Blanch Connect in order to contact the contributor
Submitted on : Friday, February 28, 2014 - 11:31:15 AM
Last modification on : Thursday, October 21, 2021 - 3:51:25 AM
Long-term archiving on: : Wednesday, May 28, 2014 - 11:16:35 AM
File
ceret-RCIS2010-final.pdf
Identifiers
  • HAL Id : hal-00953311, version 1
Citation
Éric Céret, Sophie Dupuy-Chessa, Guillaume Godet-Bar. Using Software Metrics in the Evaluation of a Conceptual Component Model. 4th Int. Conf. on Research Challenge in Information Science (RCIS'2010), 2010, Nice, France. pp.507-514. ⟨hal-00953311⟩
Share
Metrics
Record views
122
Files downloads
160
