Approximation Algorithms for Multiple Strip Packing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
n this paper we study the Multiple Strip Packing (MSP) problem, a generalization of the well-known Strip Packing problem. For a given set of rectangles, r 1,...,r n , with heights and widths ≤ 1, the goal is to find a non-overlapping orthogonal packing without rotations into k ∈ ℕ strips [0,1]×[0, ∞ ), minimizing the maximum of the heights. We present an approximation algorithm with absolute ratio 2, which is the best possible, unless P=NP , and an improvement of the previous best result with ratio 2 + ε. Furthermore we present simple shelf-based algorithms with short running-time and an AFPTAS for MSP. Since MSP is strongly NP -hard, an FPTAS is ruled out and an AFPTAS is also the best possible result in the sense of approximation theory.
hal-00953421 , version 1 (28-02-2014)
Marin Bougeret, Pierre-François Dutot, Klaus Jansen, Christina Otte, Denis Trystram. Approximation Algorithms for Multiple Strip Packing. Approximation and Online Algorithms, 2010, Copenhagen, Denmark. pp.37-48, ⟨10.1007/978-3-642-12450-1_4⟩. ⟨hal-00953421⟩
228 Consultations
0 Téléchargements
