Making Linked Open Data Writable with Provenance Semirings
Linked Open Data cloud (LOD) is essentially read-only, re- straining the possibility of collaborative knowledge construction. To sup- port collaboration, we need to make the LOD writable. In this paper, we propose a vision for a writable linked data where each LOD participant can define updatable materialized views from data hosted by other par- ticipants. Consequently, building a writable LOD can be reduced to the problem of SPARQL self-maintenance of Select-Union recursive mate- rialized views. We propose TM-Graph, an RDF-Graph annotated with elements of a specialized provenance semiring to maintain consistency of these views and we analyze complexity in space and traffic.
