X-IOTA : An open XML framework for IR experimentation. Application on multiple weighing scheme tests in a bilingual corpus - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
Carrying out experiments in Information Retrieval is a heavy activity requiring fast tools to treat collections of significant size, and at the same time flexible tools to leave the most possible freedom during the experimentation. System X-IOTA was developed to answer the criterion of flexibility and thus to support fast installation of various experiments using automatic natural language treatments. The architecture is designed to allow a distribution of computations among distributed servers. We use this framework to test different set of weighting particularly the new Derivation from Randomness against Okapi.
Fichier non déposé
hal-00953922 , version 1 (28-02-2014)
  • HAL Id : hal-00953922 , version 1
Jean-Pierre Chevallet. X-IOTA : An open XML framework for IR experimentation. Application on multiple weighing scheme tests in a bilingual corpus. Asia Information Retrieval Symposium AIRS2004, 2004, Benjing Pekin, China. pp.178--185. ⟨hal-00953922⟩
121 Consultations
0 Téléchargements
