Mapping the Lexique des Verbes du Français (Lexicon of French Verbs) to a NLP Lexicon using Examples - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Bruno Guillaume
Karen Fort
Guy Perrier
  • Fonction : Auteur
  • PersonId : 8101
  • IdHAL : guy-perrier
Paul Bedaride
  • Fonction : Auteur
  • PersonId : 837049
This article presents experiments aiming at mapping the Lexique des Verbes du Français (Lexicon of French Verbs) to FRILEX, a Natural Language Processing (NLP) lexicon based on DICOVALENCE. The two resources (Lexicon of French Verbs and DICOVALENCE) were built by linguists, based on very different theories, which makes a direct mapping nearly impossible. We chose to use the examples provided in one of the resource to find implicit links between the two and make them explicit.
DuboisCharlier.pdf (85.43 Ko) Télécharger le fichier
hal-00969184 , version 1 (02-04-2014)
  • HAL Id : hal-00969184 , version 1
Bruno Guillaume, Karen Fort, Guy Perrier, Paul Bedaride. Mapping the Lexique des Verbes du Français (Lexicon of French Verbs) to a NLP Lexicon using Examples. International Conference on Language Resources and Evaluation (LREC), May 2014, Reykjavik, Iceland. ⟨hal-00969184⟩
386 Consultations
360 Téléchargements
