Dynamic structure mediated by graphitelike Al nets on the Al2Cu (001) surface - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Physical Review Letters Année : 2012
Emilie Gaudry
Vincent Fournée
Marie-Cécile de Weerd
  • Fonction : Auteur
  • PersonId : 877005
Julian Ledieu
Connectez-vous pour contacter l'auteur
A detailed study of the (001) surface of the Al2Cu crystal using both experimental and ab initio computational methods is presented in this work. The combination of both approaches gives many arguments to match the surface plane with a bulk truncated surface model terminated by incomplete Al planes. The missing rows of Al atoms lead to a 2√2×√2R 45° surface reconstruction with two domains rotated by 90° from each other. Ab initio calculations demonstrate that the energetic cost associated with the removal of pairs of Al atoms is the lowest for the two nearest surface Al atoms (covalentlike interaction). They reveal that the remaining atomic rows of various widths are oriented according to the graphitelike Al 6_3 nets used to describe the Al2Cu bulk structure. The surface dynamics observed at 300 K at the Al2Cu surface is also presented. Finally, configurational and vibrational entropies are introduced to discuss the reduced surface plane density.
PhysRevLett.108.146101.pdf (355.47 Ko) Télécharger le fichier
hal-00974260 , version 1 (05-04-2014)
Laura Serkovic Loli, Emilie Gaudry, Vincent Fournée, Marie-Cécile de Weerd, Julian Ledieu. Dynamic structure mediated by graphitelike Al nets on the Al2Cu (001) surface. Physical Review Letters, 2012, 108 (14), pp.146101. ⟨10.1103/PhysRevLett.108.146101⟩. ⟨hal-00974260⟩
96 Consultations
242 Téléchargements
