Stability of Multistage Stochastic Programs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Optimization Année : 2006
Holger Heitsch
  • Fonction : Auteur
Werner Römisch
  • Fonction : Auteur
Quantitative stability of linear multistage stochastic programs is studied. It is shown that the infima of such programs behave (locally) Lipschitz continuous with respect to the sum of an $L_{r}$‐distance and of a distance measure for the filtrations of the original and approximate stochastic (input) processes. Various issues of the result are discussed and an illustrative example is given. Consequences for the reduction of scenario trees are also discussed. Copyright © 2006 Society for Industrial and Applied Mathematics
hal-00977507 , version 1 (11-04-2014)
Holger Heitsch, Werner Römisch, Cyrille Strugarek. Stability of Multistage Stochastic Programs. SIAM Journal on Optimization, 2006, 17 (2), pp.511-525. ⟨10.1137/050632865⟩. ⟨hal-00977507⟩
Collections
ENSTA UMA_ENSTA
63 Consultations
0 Téléchargements
