New interface
Journal articles
In situ investigations of a Li-rich Mn-Ni layered oxide for Li-ion batteries
Abstract : A Li-rich layered oxide with the formula Li[Li0.2Mn0.61Ni0.18Mg0.01]O2 was successfully synthesised and characterised using several in situ characterisation techniques. The electronic state and structural evolution of the material upon cycling were investigated using in situ XRD, EXAFS and XANES measurements. XANES and SQUID magnetic measurements showed that the initial material contains a certain amount of Mn3+ in a low spin configuration (average Mn oxidation state: +3.75). In situ measurements showed that the first part of the charge (up to 4.4 V vs. Li+/Li) corresponds to oxidation of the Mn3+ fraction, and that the oxidation of nickel occurs only later, on the main charge plateau at 4.5 V. Electrochemical and structural results tend to show that the main first-charge plateau is a two- phase process where a new phase is created. This new phase is structurally very close to the starting one, and could be an oxygen-deficient spinel with a 1⁄4 8.25 A#. This process is non-reversible, and further cycling occurs in the new phase formed in situ.
Complete list of metadata
https://hal.inria.fr/hal-00984249
Contributor : Pierre Strobel Connect in order to contact the contributor
Submitted on : Monday, April 28, 2014 - 9:57:36 AM
Last modification on : Monday, December 13, 2021 - 9:42:44 AM
Identifiers
Collections
Citation
Loïc Simonin, Jean-François Colin, Vincent Ranieri, Emmanuel Canevet, Jean-Frederic Martin, et al.. In situ investigations of a Li-rich Mn-Ni layered oxide for Li-ion batteries. Journal of Materials Chemistry, 2012, 22, pp.11316. ⟨10.1039/c2jm31205k⟩. ⟨hal-00984249⟩
Share
Metrics
Record views
297
