My Corporis Fabrica: Making Anatomy Easy - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Characters with precise internal anatomy are important in film and visual effects, as well as in medical applications. However, setting up detailed anatomical models has been a difficult task, especially for simulation. We demonstrate MyCorporisFabrica(MyCF), the first assistant tool for modeling and simulating anatomical structures such as bones, muscles, viscera and fat tissues. This is done by transferring a reference anatomical model from an input template to an arbitrary target character, only defined by its skin. Given the target character in a similar pose as the reference anatomy, and optionally a distribution of fat, the method runs automatically. This allows to quickly generate anatomical models for a large range of target characters, while maintaining anatomical constraints. Moreover, the tool includes a novel anatomy knowledge base designed to help selecting anatomical entities based on their contribution to physiological functions. Finally, the knowledge base contains mechanical data used to set up different mechanical models of the selected entities, which we export to a simulator. This dramatically eases biomechanical modeling and makes it possible for non-expert users to enter that field. The application works in a web browser. In this 20 minute talk, we demonstrate this technology and detail a practical example.
MyCF_sg14.pdf (171.11 Ko) Télécharger le fichier
MyCF_2_HD.mp4 (17.36 Mo) Télécharger le fichier
MyCF_2_LD.flv (17.75 Mo) Télécharger le fichier
Format : Figure, Image
Format : Vidéo
Format : Vidéo
hal-00987439 , version 1 (06-05-2014)
Armelle Bauer, Federico Ulliana, Ali Hamadi Dicko, Benjamin Gilles, Olivier Palombi, et al.. My Corporis Fabrica: Making Anatomy Easy. SIGGRAPH: Special Interest Group on GRAPHics and Interactive Techniques, Aug 2014, Vancouver, Canada. pp.#16, ⟨10.1145/2619195.2656302⟩. ⟨hal-00987439⟩
2372 Consultations
583 Téléchargements
