Optimizing Rule Placement in Software-Defined Networks for Energy-aware Routing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2014
Software-defined Networks (SDN), in particular OpenFlow, is a new networking paradigm enabling innovation through network programmability. Over past few years, many applications have been built using SDN such as server load balancing, virtual-machine migration, traffic engineering and access control. In this paper, we focus on using SDN as an approach for energy-aware routing (EAR). Since traffic load has a small influence on power consumption of routers, EAR allows to put unused links into sleep mode to save energy. SDN can collect traffic matrix and then computes routing solutions satisfying QoS while being minimal in energy consumption. However, prior works on EAR have assumed that the table of OpenFlow switch can hold an infinite number of rules. In practice, this assumption does not hold since the flow table is implemented in Ternary Content Addressable Memory (TCAM) which is expensive and power-hungry. In this paper, we propose an optimization method to minimize energy consumption for a backbone network while respecting capacity constraints on links and rule space constraints on routers. In details, we present an exact formulation using Integer Linear Program (ILP) and introduce efficient greedy heuristic algorithm for large networks. Based on simulations, we show that using this smart rule space allocation, it is possible to save almost as much power consumption as in the classical EAR approach.
RR-8537.pdf (762.11 Ko) Télécharger le fichier
hal-00996780 , version 1 (26-05-2014)
  • HAL Id : hal-00996780 , version 1
Frédéric Giroire, Joanna Moulierac, Truong Khoa Phan. Optimizing Rule Placement in Software-Defined Networks for Energy-aware Routing. [Research Report] RR-8537, INRIA. 2014, pp.23. ⟨hal-00996780⟩
823 Consultations
2020 Téléchargements
