Abstract : We tackle the problem of designing and programming dynamic and reactive systems with four objectives: being based on a formal model of computation, using different types of concurrency, being efficient, and tolerating failures. The challenge lies in the fact that good formal models with very high level of abstraction generally result in non-efficient implementations. We propose a 'C' based library approach following the formal Dynamic Globally Asynchronous Locally Synchronous (DGALS) model of computation. We show how a DGALS system can be dynamically constructed from concurrent behaviors on distributed platforms thanks to the DGALS paradigm. Finally, our experimental results clearly indicate the large execution time and memory footprint gains compared to the current state of the art approaches.
Type de document :
Communication dans un congrès
9th IEEE International Symposium on Industrial Embedded Systems (SIES 2014), Jun 2014, Pisa, Italy. 2014
https://hal.inria.fr/hal-00996978
Contributeur : Wei-Tsun Sun
Soumis le : vendredi 27 juin 2014 - 07:00:04
Dernière modification le : jeudi 11 octobre 2018 - 08:48:04
Document(s) archivé(s) le : mardi 11 avril 2017 - 01:57:35
