Modeling contact interactions between triangulated rounded bodies for the discrete element method - Archive ouverte HAL Access content directly
Journal Articles Computer Methods in Applied Mechanics and Engineering Year : 2014
(1, 2) , (1, 2) , (1, 2) , (1) , (2) , (1, 2) , (1, 2) , (1, 2) , (1, 2)
1
2
Calculating contact forces between complex shapes for performing Discrete Element Method (DEM) simulations is a long standing problem with no unique ideal solution. In this work, a new method to calculate interactions between arbitrary rounded bodies is presented. Each body is represented by a triangulated surface mesh, in which each triangle is associated with a unique radius of curvature. Then, normal contact forces are calculated by numerically integrating a (Hertz) contact pressure formulation over the contact area between two contacting particles. This results in a mechanistic contact description that is converging with refinement of a given triangulation and directly uses physical material properties as parameters of the contact model. After showing convergence upon mesh refinement towards the Hertzian solution, the error for non-spherical curvatures is investigated and the new model is compared with an indentation experiment of a pear-shaped object. Finally, the method is demonstrated in a simulation of gravitational packing by simulating packing of spheres, pear-shaped as well as gummy bear-shaped objects.
Not file
Dates and versions
hal-00999663 , version 1 (03-06-2014)
Identifiers
Cite
Bart Smeets, Tim Odenthal, Janos Keresztes, Simon Vanmaercke, Paul van Liedekerke, et al.. Modeling contact interactions between triangulated rounded bodies for the discrete element method. Computer Methods in Applied Mechanics and Engineering, 2014, 277, pp.219-238. ⟨10.1016/j.cma.2014.04.017⟩. ⟨hal-00999663⟩
442 View
0 Download
Share
