Homogeneous Differentiator Design using Implicit Lyapunov Function Method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The Implicit Lyapunov Function (ILF) for a class of homogeneous systems is introduced and studied. The analysis of homogeneous differentiator using ILF method is presented. Sufficient stability conditions for homogeneous differentiator are obtained and represented by a parameterized system of Linear Matrix Inequalities (LMI). The differentiation error and convergence time are estimated. The procedure of parameters tuning for homogeneous differentiator is formulated as the semi-definite programming problem with LMI constraints. The obtained theoretical results are supported by numerical simulations.
Automatique
ILF_dif.pdf (215.9 Ko) Télécharger le fichier
hal-01003992 , version 1 (11-06-2014)
  • HAL Id : hal-01003992 , version 1
Andrey Polyakov, Denis Efimov, Wilfrid Perruquetti. Homogeneous Differentiator Design using Implicit Lyapunov Function Method. European Control Conference, IEEE, IFAC, Jun 2014, Strasbourg, France. ⟨hal-01003992⟩
216 Consultations
620 Téléchargements
