Typing messages for free in security protocols: the case of equivalence properties - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2014
Our first main contribution is to reduce the search space for attacks. Specifically, we show that if there is an attack then there is one that is well-typed. Our result holds for a large class of typing systems and a large class of determinate security protocols. Assuming finitely many nonces and keys, we can derive from this result that trace equivalence is decidable for an unbounded number of sessions for a class of tagged protocols, yielding one of the first decidability results for the unbounded case. As an intermediate result, we also provide a novel decision procedure in the case of a bounded number of sessions.
RR-8546.pdf (688.32 Ko) Télécharger le fichier
hal-01007580 , version 1 (16-06-2014)
  • HAL Id : hal-01007580 , version 1
Rémy Chrétien, Véronique Cortier, Stéphanie Delaune. Typing messages for free in security protocols: the case of equivalence properties. [Research Report] RR-8546, INRIA. 2014, pp.46. ⟨hal-01007580⟩
486 Consultations
296 Téléchargements
