Fast multiclonal clusterization of V(D)J recombinations from high-throughput sequencing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue BMC Genomics Année : 2014
BACKGROUND: V(D)J recombinations in lymphocytes are essential for immunological diversity. They are also usefulmarkers of pathologies. In leukemia, they are used to quantify the minimal residual disease duringpatient follow-up. However, the full breadth of lymphocyte diversity is not fully understood. RESULTS: We propose new algorithms that process high-throughput sequencing (HTS) data to extract unnamedV(D)J junctions and gather them into clones for quantification. This analysis is based on a seedheuristic and is fast and scalable because in the first phase, no alignment is performed with germlinedatabase sequences. The algorithms were applied to TR HTS data from a patient with acutelymphoblastic leukemia, and also on data simulating hypermutations. Our methods identified themain clone, as well as additional clones that were not identified with standard protocols. CONCLUSIONS: The proposed algorithms provide new insight into the analysis of high-troughput sequencing data forleukemia, and also to the quantitative assessment of any immunological profile. The methodsdescribed here are implemented in a C++ open-source program called Vidjil.
1471-2164-15-409.pdf (504.74 Ko) Télécharger le fichier
1471-2164-15-409-S1.pdf (79.52 Ko) Télécharger le fichier
1471-2164-15-409.xml (88.58 Ko) Télécharger le fichier
Format : Autre
Format : Autre
hal-01009173 , version 1 (20-06-2014)
Mathieu Giraud, Mikaël Salson, Marc Duez, Céline Villenet, Sabine Quief, et al.. Fast multiclonal clusterization of V(D)J recombinations from high-throughput sequencing. BMC Genomics, 2014, 15 (1), pp.409. ⟨10.1186/1471-2164-15-409⟩. ⟨hal-01009173⟩
794 Consultations
284 Téléchargements
