Information Centric Networking in the IoT: Experiments with NDN in the Wild - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2014
This paper explores the feasibility, advantages, and challenges of an ICN-based approach in the Internet of Things. We report on the first NDN experiments in a life-size IoT deployment, spread over tens of rooms on several floors of a building. Based on the insights gained with these experiments, the paper analyses the shortcomings of CCN applied to IoT. Several interoperable CCN enhancements are then proposed and evaluated. We significantly decreased control traffic (i.e., interest messages) and leverage data path and caching to match IoT requirements in terms of energy and bandwidth constraints. Our optimizations increase content availability in case of IoT nodes with intermittent activity. This paper also provides the first experimental comparison of CCN with the common IoT standards 6LoWPAN/RPL/UDP.
RR-8551.pdf (2.86 Mo) Télécharger le fichier
hal-01010879 , version 1 (23-06-2014)
hal-01010879 , version 2 (02-07-2014)
hal-01010879 , version 3 (27-08-2014)
  • HAL Id : hal-01010879 , version 3
Emmanuel Baccelli, Christian Mehlis, Oliver Hahm, Thomas Schmidt, Matthias Wählisch. Information Centric Networking in the IoT: Experiments with NDN in the Wild. [Research Report] RR-8551, INRIA. 2014. ⟨hal-01010879v3⟩
353 Consultations
1376 Téléchargements
