Chipless RFID Tag Using Hybrid Coding Technique - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Microwave Theory and Techniques Année : 2011
Increasing the coding capacity of chipless RFID tags is a key factor while considering the development of miniaturized tags. A novel hybrid coding technique by combining phase deviation and frequency position encoding is proposed here. A coding capacity of 22.9 bits is obtained simply with five resonators within a reduced dimension of 2 cm × 4 cm. The proposed tag is based on 5 'C' like metallic strip resonators having resonance frequency within the band of 2.5 GHz to 7.5 GHz. The tag is potentially low-cost since only one conductive layer is needed for the fabrication. Different tag configurations are designed and validated with measurement results in bi-static configuration. A good agreement between measurement and simulation validates the theoretical predictions.
Fichier non déposé
hal-01023143 , version 1 (11-07-2014)
Arnaud Vena, Etienne Perret, Smail Tedjini. Chipless RFID Tag Using Hybrid Coding Technique. IEEE Transactions on Microwave Theory and Techniques, 2011, 59 (12), pp.3356-3364. ⟨10.1109/tmtt.2011.2171001⟩. ⟨hal-01023143⟩
195 Consultations
0 Téléchargements
