Rule Learning with Negation: Issues Regarding Effectiveness - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
An investigation of rule learning processes that allow the inclusion of negated features is described. The objective is to establish whether the use of negation in inductive rule learning systems is effective with respect to classification. This paper seeks to answer this question by considering two issues relevant to such systems; feature identification and rule refinement. Both synthetic and real datasets are used to illustrate solutions to the identified issues and to demonstrate that the use of negative features in inductive rule learning systems is indeed beneficial.
Rule_Learning_With_Negation_Issues_Regarding_Effectiveness.pdf (221.79 Ko) Télécharger le fichier
hal-01055059 , version 1 (11-08-2014)
Paternité
Stephanie Chua, Frans Coenen, Grant Malcolm. Rule Learning with Negation: Issues Regarding Effectiveness. 6th IFIP TC 12 International Conference on Intelligent Information Processing (IIP), Oct 2010, Manchester, United Kingdom. pp.193-202, ⟨10.1007/978-3-642-16327-2_25⟩. ⟨hal-01055059⟩
116 Consultations
83 Téléchargements
