Increasing Functional Coverage by Inductive Testing: A Case Study
This paper addresses the challenge of generating
test sets that achieve functional coverage, in the absence of a complete
specification. The inductive testing technique works by probing the
system behaviour with tests, and using the test results to construct an
internal model of software behaviour, which is then used to generate
further tests. The idea in itself is not new, but prior attempts to
implement this idea have been hampered by expense and scalability, and
inflexibility with respect to testing strategies. In the past, inductive
testing techniques have tended to focus on the inferred models, as
opposed to the suitability of the test sets that were generated in the
process. This paper presents a flexible implementation of the inductive
testing technique, and demonstrates its application with case-study that
applies it to the Linux TCP stack implementation. The evaluation shows
that the generated test sets achieve a much better coverage of the
system than would be achieved by similar non-inductive
techniques.
Bibliothèque électronique [cs.DL]
