Unnecessary Image Pair Detection for a Large Scale Reconstruction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper proposes an algorithm to detect unnecessary image pairs for efficient structure from motion. Since image pair with small baseline is considered as a poor condition for reconstruction, we focus on computing cameras closely located. We address a term, "remoteness" which indicates the distance between two images in this paper. The remoteness is not affected by image's intrinsic parameters because camera intrinsic matrix is applied to put the extracted features in the normalized coordinate. The remoteness is computed using feature disparity in normalized coordinate. Therefore, we can detect redundant image pair captured at the near position without reconstruction. The proposed algorithm is proved by experimental results with Notre Dame images.
icec2010_submission_59.pdf (760.34 Ko) Télécharger le fichier
hal-01055647 , version 1 (13-08-2014)
Paternité
Jaekwang Lee, Chang-Joon Park. Unnecessary Image Pair Detection for a Large Scale Reconstruction. 9th International Conference on Entertainment Computing (ICEC), Sep 2010, Seoul, South Korea. pp.151-159, ⟨10.1007/978-3-642-15399-0_14⟩. ⟨hal-01055647⟩
48 Consultations
70 Téléchargements
