Abstract : An automated process is described to assemble highly
functionalized micro fluidic cartridges. Different materials such as
glass, silicon and thermoplastics can be bonded using adhesive gaskets.
The assembling and bonding sequence is realized at room temperature so
that the biological function of the cartridge is fully preserved.
Several control tests for alignment and orientation are integrated into
the process so that a precise and reliable assembly using robotic
equipment can be achieved.
https://hal.inria.fr/hal-01055663 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Wednesday, August 13, 2014 - 12:34:09 PM Last modification on : Tuesday, August 8, 2017 - 5:09:09 PM Long-term archiving on: : Thursday, November 27, 2014 - 12:17:10 AM
Agathe Koller, Manuel Altmeyer, Silvio Walpen. Precision Assembling and Hybrid Bonding for
Micro Fluidic Systems. 5th IFIP WG 5.5 International Precision Assembly Seminar (IPAS), Feb 2010, Chamonix, France. pp.65-72, ⟨10.1007/978-3-642-11598-1_7⟩. ⟨hal-01055663⟩
