Secure and Usable Out-Of-Band Channels for Ad Hoc Mobile Device Interactions
Protocols for bootstrapping security in ad hoc
mobile device interactions rely on users' ability to perform specific
tasks such as transferring or comparing fingerprints of information
between devices. The size of fingerprints depends on the level of
technical security required by a given application but, at the same
time, is limited by users' inability to deal with large amounts of data
with high levels of accuracy. Large fingerprints provide high technical
security but potentially reduce usability of protocols which may result
in users making mistakes that compromise security. This conflict between
technical security and usability requires methods for transferring
fingerprints between devices that maximise both to achieve acceptable
effective security. In this paper, we propose two methods for
transferring fingerprints between devices. We conducted a usability and
security evaluation of the methods and our results show that, in
contrast to previous proposals, our methods are both usable and
resistant to security failures.
Bibliothèque électronique [cs.DL]
