Temporal multi-frequency encoding technique for chipless RFID applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A novel temporal multi-frequency encoding technique based on group delay for chipless Radio Frequency Identification (RFID) tag is presented. Cascaded microstrip transmission line sections coupled at alternative ends (C-sections) are utilized to generate the tag Identification (ID). C-sections are dispersive structures, have a group delay maximum at different frequencies which is purely dependent on the length of the C-section. The proposed device is designed, prototyped and experimentally verified for 2 bit coding. The obtained results confirm the concept and its use in chipless RFID applications. Furthermore the transformation of the prototype into chipless tag using simulation results is also incorporated.
Fichier non déposé
hal-01056723 , version 1 (20-08-2014)
Raji Sasidharan Nair, Etienne Perret, Smail Tedjini. Temporal multi-frequency encoding technique for chipless RFID applications. Microwave Symposium Digest (MTT), 2012 IEEE MTT-S International, Jun 2012, Unknown, pp.1-3, ⟨10.1109/mwsym.2012.6259483⟩. ⟨hal-01056723⟩
Collections
UGA LCIS
57 Consultations
0 Téléchargements
