Conference papers
RFID chipless tag based on multiple phase shifters
Abstract : The RFID chipless tag presented in this article uses a new technique for data encoding. It is based on changing the phase of multiple resonators that behave as phase shifter. This technique brings a much higher reliability than for the actual absence/presence of resonance encoding way. The design proposed is based on 5 reflective strip resonators having resonant frequency starting from 2.5 GHz to 6.5 GHz. A capacity of 10 bits is reached within a reduced size of 20 × 40 mm2. Tag made on this principle is potentially low cost because only one conductive layer is needed for its fabrication.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-01056738
Contributor : Valence Lcis Connect in order to contact the contributor
Submitted on : Wednesday, August 20, 2014 - 2:29:13 PM
Last modification on : Friday, November 6, 2020 - 4:36:59 AM
Identifiers
Collections
Citation
Arnaud Vena, Etienne Perret, Smail Tedjini. RFID chipless tag based on multiple phase shifters. Microwave Symposium Digest (MTT), 2011 IEEE MTT-S International, Jun 2011, Unknown, pp.1-4, ⟨10.1109/mwsym.2011.5972712⟩. ⟨hal-01056738⟩
Share
Metrics
Record views
102
