Abstract : These instructions give you guidelines for preparing papers for IEEE conferences Use this document as a template if you are using Microsoft Word 6.0 or later. Otherwise, use this document as an instruction set. Instructions about final paper and figure submissions in this document are for IEEE journals; please use this document as a "template" to prepare your manuscript. For submission guidelines, follow instructions on paper submission system as well as the Conference website. Do not delete the blank line immediately above the abstract; it sets the footnote at the bottom of this column.
Bruno B Albert, F. M. Assis, Smail Tedjini. Random modulation privacy for RFID channels. RFID-Technology and Applications (RFID-TA), 2010 IEEE International Conference on, Jun 2010, Unknown, pp.176-181, ⟨10.1109/rfid-ta.2010.5529936⟩. ⟨hal-01056842⟩
