Orcc's Compa-Backend demonstration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2014
This paper presents the implementation of a video decoding application starting from its dataflow and CAL representations. Our objective is to demonstrate the ability of the Open RVC-CAL Compiler (Orcc) to generate code for embedded systems. For the demonstration, the video application will be an MPEG-4 Part2 decoder. The targeted architecture is a multi-core heterogeneous system deployed onto the Zynq platform from Xilinx.
poster_dasip_2014.pdf (339.26 Ko) Télécharger le fichier
hal-01059858 , version 1 (23-10-2014)
  • HAL Id : hal-01059858 , version 1
Yaset Oliva, Emmanuel Casseau, Kevin Martin, Pierre Bomel, Jean-Philippe Diguet, et al.. Orcc's Compa-Backend demonstration. Conference on Design and Architectures for Signal and Image Processing, Demo Night, Oct 2014, Madrid, Spain. 2014. ⟨hal-01059858⟩
694 Consultations
268 Téléchargements
